frankt8242 said:Easy if you know what you're doing....Otherwise fuggeddaboutit!!...BTW why..??? :roll: :roll: :roll:
Perhaps because I'm amused about how "anal" some of us get over @ .1mm of crown thickness..???...That's a triple rolleye at least IMNSFHO!!... :roll: :roll: :roll:hooligan said:frankt8242 said:Easy if you know what you're doing....Otherwise fuggeddaboutit!!...BTW why..??? :roll: :roll: :roll:
Uh, probably because he wants to install a more accurate crown. Why all the rolleyes?
As far as tools go, you'll need a case back remover of some sort (a bunch of balled-up duct tape will work) and a small screwdriver. It's not that hard, but it's EASY to unscrew the set-screw too far and then it's a pain to get the winding stem back in. My advice would be to send it off to have someone do it for you. Plus, if you're installing a thicker crown, you might need to grind down the CG lever a bit in order for it to fit properly. That's something best left to someone with experience, IMO.
Yeah...just like a lightbulb,,,LOLewing said:thanks!
it's very nice of you...
if the offer is still valid when I receive the parts, I'll try to contact you...
are there adjustments to be done when changing a crown for another or it's like changing a lightbulb?
do you keep good Ti crowns in stock?
frankt8242 said:Perhaps because I'm amused about how "anal" some of us get over @ .1mm of crown thickness..???...That's a triple rolleye at least IMNSFHO!!... :roll: :roll: :roll:
I'm not even sligthtly "spun up" but more concerned about a rep lover getting in over his head trying to fix "what ain't broke", and screwing up a decent rep trying to strive for a level of "perfection" that is unreasonable...The crown's mat be a tiny bit skimpy, but a watch in parts a baggie is wayyyyy worse !!hooligan said:frankt8242 said:Perhaps because I'm amused about how "anal" some of us get over @ .1mm of crown thickness..???...That's a triple rolleye at least IMNSFHO!!... :roll: :roll: :roll:
Wow, I didn't know you got so spun-up over what other peopi"e do to their watches. BTW, the crown that is currently on that watch is way more than .1mm too thin. :wink:
frankt8242 said:I'm not even sligthtly "spun up" but more concerned about a rep lover getting in over his head trying to fix "what ain't broke", and screwing up a decent rep trying to strive for a level of "perfection" that is unreasonable...The crown's mat be a tiny bit skimpy, but a watch in parts a baggie is wayyyyy worse !!
There are a dozen ways a newbie can screw this up....Why encourage it...???
