So is this a simple fix such as just rotating the watch and rotate the dial? I understand the movement will be upside down but the front should be ok?
Or just put another movement in there?
Really love the 112...not sure I can get used to the 219.
You can split the dial like you were going to relume it, also a good time to do so, sand off the little feet between the 2 dials and reglue them the other way. This will be the simplest way to do it.
Like the Gentlemans said it would be difficult, but if you are not hurry the 112 will be launch by the Hublot factory (219,005, etc...) likely at the end of march.
Well that's what a dealer told me coze me too i wanted a 112, my first solution was to buy the new 111J & negociate just the new 219 dial.
