CG pin self-mod?
drfcfighter
1,307
Hi have a 36 with CG pin flushed on the back but dimpled on the front. Any suggestion as to how to flip it around so that the pin is flushed with CG?
Natron
1,419
you can gently tap it from the back and flush it up with the fron. That is what I have done with my two Pams
Natron
drfcfighter
1,307
Yep, good method. I actually wanna switch the pin out and put it back in as the front has a dome and the back is flush. Can it come out like a pin link?
ddesj74
67
I did this mod on my 36, the pin will just pop out, but you have to drill out just a bit to have it sit flush once you flip it.
Denis
babola
1,660
79
Denis
So what did you do with the larger hole at the bottom of CG to minimize play and secure the thinner side of the pin ?
@natron,
yup that works on standard rep CG's but the lever pin on 036 CG is installed upside down (thin end @the top, thick @ the bottom), so for a nice flush finish on the top, it (pin) needs to be reversed, i.e. installed from top down.
cheers,
babola
