CG pin help
faberjay111
2,738
Hi Pam experts!
I have recently bought a beautiful 113(gen dial and hands with a Swiss movement. I absolutely love it. Howvever, I notice that the CG pin is not flush with the CG. It is a little "pushed in".
Is there a simple DYI fix that I can attempt? Or should I try to find a new GC pin? Or should I send it to a modder?
There is also no "snap" when I push in the lever. Can this be fixed?
Here is a picture....
faberjay111
2,738
Congrats on the great watch...Where'd you score that?
to fix the pin...The hot glue fix:
http://vintagewatchparts.co.uk/index.php?id=108
it will tighten things up nicely. When you put the pin back in push it back in flush. simple.
Thanks! I got it from a member on RG. It's an Oncyte build with a gen dial and hands and a T48 crown(actually, I don't know what a T48 crown is, but apparently they are very nice!).
I will attempt the DIY.
Thanks again....see you on Saturday!
ALE7575
Section Mod
19,846
423
The CG PIn in gens is a little recessed, not so much as yours but a bit recessed, bear it in mint
ALE
ALE7575
Section Mod
19,846
423
Since your dial is a gen
Could we have macro pics of markers and subdial @9? in order to make comparison reviews with the current replicas?
Pics with movement and dial decased would be appreciate
Thanks in advance
ALE
faberjay111
2,738
Thanks in advance
ALE
Ok, I will try...but my photography skills are VERY limited!
faberjay111
2,738
Oh yeah...with regards to the movement and dial de-cased...it won't happen!
The extent of my watchsmithing skills is solely and purely dedicated to strapchanging! But, in that field...I am an expert!!!
D
d4m.test
Guest
ALE
Anything you get from Oncyte will be correct to the smallest detail including the CG pin. That guy does amazing work.
I was assuming he wanted it flush out of personal preference.
ALE7575
Section Mod
19,846
423
Yes Grim I get it
Thanks
ALE
winz
189
I think CG is correct, CG pin on gens is flat or sunken.
but i prefer sunken look than flat, imho
most ootb reps have recessed CG pin
