My beloved DSN 104 appears to be in need of a new CG. I took the CG off to try out the look of a polished case with a brushed CG. Everything went back together as expected, however, I notice that the CG lever does not push the spring loaded crown down equally, and the crown is depressed at an angle, with the contact point not touching the crown in the center, but more forward, toward the buckle lug end.
Is the Toro Crown that was available a while back compatable with the DSN 104? Or what would be a good replacement CG for this watch?
Thanks, Marty
Thanks, Marty
