Any hot tips for me on where to source a new crown and stem(s) for my clean OP41 with a VR3230? Couldn't find any threads on this. I'm kind of clueless when it comes to some of these newer clones. Assuming the VR3235 stem is the same as 3230?
The VR3235 is not the same as gen in many ways i've read, so is it's stem design borrowed from another movement that can be found on ebay for example?
P.s., for anyone needing to disassemble the cleans crown/stem on op41s, they are super duper cemented in, be sure to use acetone bath to dissolve the cement first, then a little heat. I chewed mine up a bit.
