CF click spring replacement
WolfKissed
503
563
California
Bought the newly released CF GMT Master II Pepsi and the click spring seems…. Non Existent? Lol
Looking to replace it but only springs I see on eBay are for 16710. Anyone know if the gen2: 216710 (which this is a Rep of) has any difference at all in the click spring or are they absolutely the same?
Mr.Lee
73
56
I will replace mine with a gen one in about a week. If you’re interested you can get mine
g-yice
Repper 2.0
954
938
Well I also have a CF one xD. The bezel movement is really bad :/ but thanks ;)
Gesendet von iPhone mit Tapatalk
Mr.Lee
73
56
They are not all the same. Some of them work fine… I don’t replace mine because it doesn’t work ????
WolfKissed
503
563
California
Ordered one yesterday and will Tell you when it arrives
Yes please keep me posted! If you get that satisfying *click* when rotating bezel after replacing with the new spring.
It’s not like I NEED it as I don’t really set my bezel to another TZ ever but I am that guy that no and then rotates the bezel because I find it satisfying to hear that *click click click*. Haha
Reactions: g-yice
WolfKissed
503
563
California
Just a question. How much have you paid for the gen clickspring? I am also looking for one but had so far no luck.
I can't quite attest if I'm getting a true GEN spring but on Ebay, what was marketed as such was only $8 plus shipping. Cheap enough for me to buy and try cause anything will be an improvement from current status as my bezel spring is virtually non existent.
JayBee0815
Repoholics Anonymous
9,502
29,175
Heart of Europe
Ok, then it is not Gen. But if is s a cheap solution for the problem. Please tell us, if this works.
WolfKissed
503
563
California
Fail…
Replisimio
1,131
1,122
Gods own country! Yorkshire.
Did you not see a pic of what you were buying! This is indeed a click spring for a 5 digit Submariner. We’ve all done that though when getting parts for these!
domiffm
handsome
5,663
15,903
Fail…
The bezel of the GMT Master II is not supposed to *click* (not like the click from a Submariner). It's more like a smooth rotation with a softer resistance. This round clickspring is connected to the bezel and runs over the waves of the retaining ring during bezel rotation. Every time these inner „spikes“ from the spring run over the waves only a smooth click will be created. Sometimes these chinese clicksprings rings are "bent" wrongly so that it runs too loose/too soft or too tight over the retaining ring. It helps to play with the bending of the spring.
Did you remove the bezel with a knife without taping the case? I hope the scratches on the lug are not that bad.
Reactions: g-yice
g-yice
Repper 2.0
954
938
I couldn´t wait so mine has a gen click spring now ;) If the other one I ordered arrives on some time, I will sell it here
g-yice
Repper 2.0
954
938
My watchmaker had one over :)
