case & mov from Noob 111N v3?
Yandex
15
I do not need help any more! my photo - it's Noob 111 N v3!
ALE7575
Section Mod
19,846
423
Hi Yandex
I had studied a little your published pics before you delete them
It didn't seem a PAM 111 N V3
Movement seemed an old LOW beat modified with a Gen Incabloc and gen Lyre spring. with a long micrometric screw.
But it seemed an old LOW beat movement with rounded blue screw surface.
Case was impossible to identify by the pics
CG seems Noob V3
What are you trying?
A little weird this thread
Any explanation?
ALE
Yandex
15
Thanks ALI
After story with PAM 366 "Fu" my "watchmaker" tried to present these details as gen.
But after examination of the theme "Reference PAM REVIEW-GUIDE" I decided that these case and movement are by Noob 111 n v3 and not gen. I would like to have confirmation of this fact.
The movement has the same numbers as noob (514818),the same problem is with letter "i" in "panerai" (the height of it is less than the other letters have). Also at the picture near by the movement you can see "swan neck" like in noob v3. And according to the font of engraving used for case series number it's also made by noob, moreover all ref. numbers of noob start with BB 140xxxx.
for example gen case:
http://i46.tinypic.com/2pyb1p0.jpg
photo case & mov from my watchmaker:
https://www.dropbox.com/sh/kii336yxtnn8d8c/KHM_SuLen2/NoobV3
ALE7575
Section Mod
19,846
423
That is worse my friend, because the movement (most likely a Noob) is not even V1, V2, V2.5 or V3, but it is an old movement Asian 6497 LOW beat modified with Gen Incablock and gen Lyre spring and with long micrometric screw. See the big blance wheel and the rounded blue screws surfaces.
Only the CG seems a last series Noob. Caseback has also some differences that I don't understand either
ALE
Yandex
15
I think that movement was assembled with usage of different details both gen and Noob parts.
Regarding origins of case I can draw a conclusion just on the base of caseback. It looks the same as all the cases in the topic about noob 111 n v3 and I don't think that the case was composed of different parts.
