Hi guys, I have this PAM 390N and it worked fine for last 1 year(worn very few times). The other day I unscrewed the crown to set time and then wind it. But once i changed the position of the screw to set time, it is stuck. Not able to pull it further or push it inside. I can't even close the lever incase it breaks. What is the solution for this issue? Thanks.
