brtelec said:If you look at your Panerai the pin in the center of the watch that the hands attach to, is typically recessed slightly. On a gen Panerai this pin is flush with the hands. This is a tell tale sign that the watch is a rep. Well one of them anyway.
NYC Tag Lover said:brtelec said:If you look at your Panerai the pin in the center of the watch that the hands attach to, is typically recessed slightly. On a gen Panerai this pin is flush with the hands. This is a tell tale sign that the watch is a rep. Well one of them anyway.
Thank you for your reply.
Could you tell me why would a rep dealer would give you the option to fix this at an extra cost? I'm thinking tat they should fix this since a rep should be as close to a gen as possible. Is there a functionality problem if this is not fixed?
Thanks again
R2D4 said:NYC Tag Lover said:brtelec said:If you look at your Panerai the pin in the center of the watch that the hands attach to, is typically recessed slightly. On a gen Panerai this pin is flush with the hands. This is a tell tale sign that the watch is a rep. Well one of them anyway.
Thanks again
Well unfortunately these makers are after your money. They bang em out as cheap as they can get away with and keep the perfect ones for themselves. Us cheap arses get to complain about it and push more money their way. If you think of buying a new car at the dealership it doesn't feel as painful.Seat belts are an option? SOMEBEECH!
daytona4me said:It's just and aesthetic modification.. that is all...
