Can the front glass be removed from case?
bangsters
2,013
21
Hey. I am starting to franken one of my watches. I want to switch the case set with a noob 111. However, the 111 case does not have the magnified glass. Can i remove the glass or that is fixed and not possible? Or maybe just the cyclops from the other case can be removed instead?
Any suggestions?
Sent from my HTC 10 using Tapatalk
mysterio
9,794
864
You can remove the crystal. You can push it out from the inside. You do have to remove the movement from the case first. But you need a crystal press to attach a new crystal on the PAM111 case. You cannot transfer the cyclops from a PAM crystal (it's not like a Rolex where it's attached to the crystal). The cyclops on a PAM crystal is etched from the inside of the crystal. So the crystal and cyclops come together.
