Nice, I will try this!Pop the spring pin out that holds the thumbnail on, position the thumbnail in the correct hole and then reattach the pin. The two sleeves that keep the bar of the clasp centered are a PITA but you'll figure them out after a few drops...
Good strap, great combination. What is its thickness at the very end of the tongueI’m struggling to thread this rubber into the butterfly opening. Is there a smart way to do this or is the strap too thick?
I have to measure it! I will to to fit it if not I will shave if the tongue a bit!Good strap, great combination. What is its thickness at the very end of the tongue?
Not necessary.I have to measure it! I will to to fit it if not I will shave if the tongue a bit!
I haven't measured mine yet but no workaround was working.Not necessary.
I just wanted to know the thickness of your strap. All the last arrivals to me have to thin 2.2mm
thick. Mine, from old reserves, has 3.5 mm.
