Om3ga guy is correct... and looking at the invoices, I stand corrected. Ofrei has the gen clasp for 146.50 and the 1580/952 SEL's for 59.00 each, 118.00 for the pair. The gen tubes and pins worked perfectly on mine for the clasp and I used the gen tubes with rep pins to mount the SEL's to the bracelet. I used the bracelet pin removal tool to pull the rep pins/tubes, slightly crimped the gen tubes on each end, put them in the SEL's, slightly bent the rep pins to a more of a "bow" shape (for better tension) and used a small, hard plastic headed ball-peen to tap the in...no problem at all. I didn't have an issue with the length of the pins as I used the rep pins again. IMHO, the gen SEL's are a very nice upgrade as they completely eliminate that bothersom gap between the SEL and last bracelet link.
NOTE: the rep 2mm spring bars ( x 20mm) worked great and put the SEL's "very" tight to the case (lug to lug is perfect too, but so was the rep SEL's) but they took a bit more effort to get in.
I actually pushed one side of each springbar all the way in and squeezed the outer bar tube just enough to hold it in while using a small watch screwdriver to push the other side in and get it to spring into the case hole. Then slowly worked the other side spring lose and to the case...I needed to pry it back as the springbar pin was approx .25mm from lining up.But it went in fine and when they're in they ARE in...tight tight. I just thought I'd share what worked for me...and using a 10x visor loupe "really" helps me.
Fakemaster sells bracelets....just PM him.
Correctime, where are you seeing $130.00? The clasps covers alone are more than that...
http://www.ofrei.com/page666
And that's just the outside of the clasp, not the full assembly.
Search OME-117ST1580952 it's showing 146.50 per clasp
