Broken and in need of advice!
koln99
15/9/14
Hi all
My replica as you can see has missing parts. Does anyone know exactly what parts I need to get and where I can try getting them from?
I had recently bought a 505 rep but the strap was loose and I managed to smash the screen.
I am now minus a working rep and I am keen to see if I can fix my original one!
Thanks
KBH
7,168
Crown, crown guard, and stem for starters.
larger654
MULTI ACCOUNT
3/9/15
26
i HAVE ALL THESE BUT FROM A 111 WILL THEY FIT DOES ANYONE NO
Uberschall
312
The watch in the picture looks like a PAM 171 without any titanium.
Can you recall where you purchased it and what the factory that made it could be? This would help in determining what parts would actually fit with the least amount of work.
As KBH stated, it would require the stem, crown and CG. Since The watch uses a Bettarini (as opposed to a 1950) case, it would have to have a CG without "REG. T.M." on it if possible. While the PAM 111 uses a Bettarini case, I am not sure that the parts would be a direct fit.
Uberschall
312
As far as the PAM 505 is concerned, assuming that you bought either the KW or ZF version, it should have come with a sapphire crystal. You should contact the TD you bought it from and see if they would be able to source a new crystal for you, then find a rep-friendly watchmaker or our resident PAM-wizard [MENTION=35495]Strodda[/MENTION], unless you feel comfortable with replacing it yourself.
