Breitling Navitimer 8
Thenextpage
105
Has anyone had this rep model? I’m considering it. This will be my first model from TF factory. I’m curious about the date numbers on the rep: the numbers are very well centered in the display box on the gen, but the numbers on the rep appear to be off-centered to the right of the display box. Not sure if that’s just an issue with the photo angle though.
And if you know; what kind of life span can I expect from the A2824 movement?
Thank you!
https://chazingtime08.io/product/na...-best-edition-blue-dial-on-ss-bracelet-a2824/
Maximillian
3,045
5,905
Böhmerwald
That's a weird question that comes from a member of 10 years. The lifespan of a movement mostly depends on how you maintain it. If you treat it well and maintain a full service periodically say every 5 years, a well-developed and evolved movement like A2824 can last for generations. And if you think it's not worth servicing a rep Asian movement, swapping with a new A2824 wouldn't cost you much.
Thenextpage
105
Thank you. Although a long term member, I’ve only owned 3 rep models. One of them broke and it’s been sitting dead for years. Maybe I can replace the movement.
I’d also like to know about the lume on this Navitimer model, if anyone who’s owned it knows about that - and about the date numbers.
Thanks!
Ghost0481
Probus Scafusia
11/7/22
214
332
I had one a while ago…
The watch is not bad at all in my opinion .. but i can’t say how accurate to gen 🤷🏻‍♂️
Try to get a discontinued one from zf .. should be better due to the dial
The Lume is very bad on the TF one … but i have heard the Lume on the gen is also not the best ..
valdo568
Watch lover
46
42
Im looking for one also, ideally M2M if anyone is looking to sell
