taxman said:you can fix the problem yourself. just pull out the crown, as if you were going to reset the time, then push the stopwatch push-button that is located at the 2:00 position, keep pushing it again and again till the second hand is at the 12:00 position, then push the crown back in. this will fix the problem.
