Well I got the strap from ewatchparts....it's not a true OEM/rep 1:1 replacement. If you want to simply replace the entire strap with a generic one, it will fit that bill.
The screw and pins in the adjustable links are not OEM style, the end links to the buckle are solid vs multi, and the buckle itself has different joints.
I wanted to retain the Rep Breitling engraved buckle and I was hoping to simply salvage a pin and tube, which was a no go. I then attempted to swap buckles, but couldn't figure how to take apart the rep buckle.
Only way I was able to get this retain the rep look was to create a hybrid rep/ewatchparts bracelet.
End link is solid vs rep which was multi piece at end link to buckle.
Ewatchparts link on left has no engraving on underside vs rep bracelet on right.
Differences in buckle clasp.
Rep is left, ewatchparts is right.
Used loctite on all screws to secure this guy so there is no next time!
