- 5/11/12
- 1,068
- 186
- 63
I always hated not being able to wear most of my watches in the summer so earlier in June I purchased a Chinese water resistance tester.
I first tested watches that I had previously sent to watchsmiths and that were supposedly made water resistant and tested to 5 or 6 ATM, to my surprise most failed the test, even at 3 ATM. This is pretty scary knowing that I had been swimming with them all this time (luckily everything was fine once I opened them)...
Since I had Seiko silicon grease and a Bergeon lubrigaskets I went on to grease all the gaskets etc... After which, once again most watches failed the test. Some of the watches that failed were JF AP diver v7 and noob v3.5, Forged Carbon Diver Noob v4, Noob AP Roo chronos, Noob v7 submariners, JF AP 15400, PAM Luminors...
The only rep that passed to 3 and 5 ATM after I greased all the gaskets was my Pam26K.
I also tried with a gen watch and it also passed to 5 ATM.
PASS:
FAIL:
I dont know what conclusion to draw form all these tests:
1- The tester I am bought is crap
2- Its very hard to make reps water resistant and some watchsmiths/modders dont go through the hassle of really testing them.
3 and most likely scenario- I am doing something wrong, may it be in the testing or the greasing/sealing of the watches.
For the test here are the steps I followed:
1- I fill up the water till the red line
2- place the watch above the water, pressurize the tester till 3ATM, wait a minute or so for the pressured air to get in the watch
3- drop it in the water and lock it in, wait a minute or so and observe the watch to see if it leaks
4- release the pressure progressively and everytime I release a bit I check the watch for bubbles.
If bubbles come out of the crown/crystal etc I bring the watch back up before I release the rest of the pressure. If no bubbles come out of all the possible entry points then it passed and I go on to test at 5 ATM.
I am aware that air can be trapped in some areas which are not in the sealed part of the watch but everytime the bubbles would come out from the crystal/crown or bezel and case-back screws (APs).
To make the watch water resistant I simply grease all the gaskets and tighten the caseback, crown as well all the possible screws.
Would really appreciate input on what I am doing wrong. Thank you.
PASS:
FAIL:
