- 24/5/25
- 5
- 0
- 1
I was wondering if anyone knew if this was available to be purchased and installed on an existing Rolex rep (Clean factory)?
Hiya you need to read the group rules for mew peops firstI was wondering if anyone knew if this was available to be purchased and installed on an existing Rolex rep (Clean factory)?
However in answer to your question, im gonna guess you mean the Blue Dial from the White gold version of the GMT BLRO?
If so you might find one on Ali express I guess or ask on of our numerous trusted dealers or the easiest solution is to purchase the white gold version of one but not seen many on the new movements on the vr3186 so the dial might or might not fit, in reality nt worth the hassle really
That is the white gold 116719 or 126719 version and as Reaps says there are few that sell them ready made or you would need to look on Ali for a dial but as i said it would be easier to buy the WG rep version rather than trying to swap out a dial. Or buy both and swap the parts as required, not sure if the dial will just swap over though as the new Clean GMT 126710 BLRO, BLNR etc.... all use the DD3285 clone movement so the SH3285 might just fit. https://trustytime168.io/index.php?main_page=product_info&cPath=1_5&products_id=28199 this is probably cheap enough to use as a transplant if its what you want but the weight will be off as they are not the tungsten versions and never had a jubilee bracelet option.Did I break any rules? I thought I read through all of the guides and didn't see anything about the post rules.
I meant the blue dial with the Pepsi crown, like this one: https://www.jomashop.com/rolex-watch-m126719blro-0003.html
I know no Trusted Dealers have the Pepsi with the blue dial, so I'm ordering the regular Pepsi. But I'm just curious if there were aftermarket blue dials that could be installed on it.
Sorry about the model number confusion, I'm not very well learned on this stuff obviouslyThat is the white gold 116719 or 126719 version and as Reaps says there are few that sell them ready made or you would need to look on Ali for a dial but as i said it would be easier to buy the WG rep version rather than trying to swap out a dial. Or buy both and swap the parts as required, not sure if the dial will just swap over though as the new Clean GMT 126710 BLRO, BLNR etc.... all use the DD3285 clone movement so the SH3285 might just fit. https://trustytime168.io/index.php?main_page=product_info&cPath=1_5&products_id=28199 this is probably cheap enough to use as a transplant if its what you want but the weight will be off as they are not the tungsten versions and never had a jubilee bracelet option.
Good luck but in my opinion not worth messing about with unless you just want it for the project as I doubt the blue colour of the dial will mimic the gen all that well.
The other factor is people really wont notice the difference from afar as the 126710 blro is on an oyster now too so the WG model even in the gen world is less coveted unless you really luv gold, that is.
The blue dial does suit the watch for sure, and ive just looked at the gens and the prices for the ***719 blro are really not that bad in comparison to the stainless models considering that it is white gold.
Good luck let us know how you get on.
Oh just one further question. I think for me its best to just follow the Excel spreadsheet, but there isn't a listing that I see for either of the **719s right? Is there not enough reps to really make a list of the best ofs? Or if you're going for closest to gen its best to stay away from the rarer models like these?That is the white gold 116719 or 126719 version and as Reaps says there are few that sell them ready made or you would need to look on Ali for a dial but as i said it would be easier to buy the WG rep version rather than trying to swap out a dial. Or buy both and swap the parts as required, not sure if the dial will just swap over though as the new Clean GMT 126710 BLRO, BLNR etc.... all use the DD3285 clone movement so the SH3285 might just fit. https://trustytime168.io/index.php?main_page=product_info&cPath=1_5&products_id=28199 this is probably cheap enough to use as a transplant if its what you want but the weight will be off as they are not the tungsten versions and never had a jubilee bracelet option.
