I'm not sure you will find a brand new Moonie for under $200. I'm assuming you're talking about the ST-19 handwind model. This rep does have flaws; flat crystals unlike the domed crystals of the gen, sub dial spacing(can't do anything about that) and the subdial @6 pegged to the hour hand.
There will definitely be additional costs if you want to make it as close to gen as possible; Gen crystal + Frozen subdial @6 mod.
As for your question, almost any TD can get you one, almost all of them will be the same and probably not for under $200. You can try and look around for the 'reduced' model(Omega released two models, a 38mm version and a 42mm one) or the quartz version. Not sure how much those ones will cost or look in the M2M sales.
