Best Rolex 16610 Kermit Insert?
Circarama
225
65
Sunny California
I recently purchased a nice used BK 16610LN Submariner from BP factory. I'd like to swap out the black insert for a green one and may eventually even have the dial replaced with the correct one for the Kermit Sub. I searched RWI for a thread that might help, but could't find one so I thought I'd reach out to the membership for help.
I tried to get a JF green insert from Trusty without luck, but I do see several inserts available on eBay and I'm wondering if anyone knows which is the most gen-like available on ebay? There is also a ceramic version which, of course, is fantasy but I'd like to hear if anyone has tried one of those too.
Thanks in advance for any help you can offer.
mari115
4,439
2,484
Nearer than you think
Try asking some TDs for the LV insert, you should be able to get the ARF LV one, not the best, but not bad, at all.
For the dial, get a BP LV dial for 3135 movement, it's very nice
Reactions: Circarama
p0pperini
Uses Too Many Big Words
9,640
35,430
If you do pursue the project, you’ll also need the maxi hands to go with the jumbo dial. Converting a rep LN to a rep LV seems like a lot of hassle - you might be better off waiting for a complete Kermit to come up for sale.
muiramas
Aristocrat
18/1/17
6,059
7,989
https://forum.replica-watch.info/forum/rolex-tudor-replicas/8590480-making-this-bp-kermit-better
Circarama
225
65
Sunny California
It does seem like a lot of work. Maybe I should buy a new one and have BK swap the movements. :shrug:
mari115
4,439
2,484
problem is that the ARF kermit is trash basically, you'll have to change crystal, DW, maybe click spring for the bezel and dial maybe
Circarama
225
65
Sunny California
muiramas
Aristocrat
18/1/17
6,059
7,989
Thanks so much for sharing that link! Very informative post. The only downside was no link to a good insert.
I did a little looking on eBay and found one with the right shade of lime green. Take a look...
https://www.ebay.com/itm/GREEN-KERMI....m46890.l49292
I thought
KJ2020 put a link to an insert in there? He’s probably best placed to advise on improving this watch...
Myself, I’m going to transfer the insides of my ARF sub over soon. I got a 2824 version of the BP.
I too would like a darker insert to the lime one. I know the lume will be the wrong colour, but I can live with that...
XpanzerX
1,043
492
I actually did the same and swapped a ARF 2824 set into a TC case, I still have that set, but I’m swapping back to 3135 with the correct dial and hands, couldn’t do the mismatched lume.
XpanzerX
1,043
492
There also is a nice insert on eBay, if I can find the link I’ll post it. But the color isn’t perfect. The ARF insert has that weird hangman on the 20.
mrln
292
176
Time to pull the thread out of the sunken...
I am facing the same problem. Have purchased the following inlay: https://www.ebay.com/itm/184325071457?hash=item2aeaa16261
Quality is great! But I want to mount it on a Ginault OR1. And here comes the problem. The Insert is too thick. Can't put it pressure fit into the bezel-ring with a click.
Does anyone have experience with an OR1 regarding an insert? I think I definitely need a thinner one.
Thanks!
