Hi,
I have been working on a 111H built on different part (LH,T,Toro,Cartel) and need some help mounting the CG.
It no problem to fasten the Toro CG, fits perfectly on a Cartel case, but the lever can shut since the crown seems to thick!
Even if I remove the seam it's still not possible!
So as I can see it, my only option is to file down the lever???
Is that really the way you mount a Toro CG?!?!?!
Have any other used this combination (T crown and Toro CG) that can help me?
cheers
cheers
