[ASK] How to Reset ChronoGraph Second Hand to Zero?
ryan_sarchan
6/10/12
14
i have pam 308 h-factory...
if i push B button to reset chronograph (at 4) the minute hand back to zero...
but the second hand to one/two second...
how to reset the second hand to zero? (at 12)
thank you very much for help...
flyr
973
I believe the hand has slid out of position in the tube. The second hand will have to be removed and repositioned and possibly the tube needs tightening. I'm sure someone with greater know how will be able to shed more light on your problem soon. Good luck!
trailboss99
Head Honcho - Cat Herder
Administrator
43,648
17,461
No need flyr, you got it in one.
This will require a watchmaker to stake the hand probably as simply removing and resetting it is likely to result in the same thing happening again.
marlin2284
Supporting Vendor
Supporting Vendor
1/2/12
833
27
+1
smokiedabong
3,546
12
Is there a glue that can be used to set the hands into place? Is this a technique any watch smiths use? I did manage to glue a seconds hand once pretty well into place by mistake, I painted it and it had a trace of fresh clear coat inside the tube when it was set, that glued the thing pretty well into place.
