ARF SD43 rotor removal
35,826
71,974
Hey guys, I'm not familiar with this rotor attachment. How is this rotor removed?
Thanks.
Hor-Fan
When the going gets weird
4,838
5,964
Bat Country
I'm pretty sure the jeweled plate in the center of the rotor is just glued on, with a standard rotor screw underneath.
Sent from my iPhone using RWI
35,826
71,974
Thanks Pelagic for the answer to this question. He used a triangular head screwdriver for his project. The are 3 little detents in the decorative rotor screw head, the whole thing rotates off. I did not have a triangular head screwdriver and was going to grind down a square bit to a triangle shape but I found that a T-5 star bit was the right 1.2mm size to catch those detents perfectly.
Reactions: DD60
