APSF Daytona 116500, the first ShangHai 4130 Movement, 72H+ Power Reserve
puretime
Trusted Dealer
Trusted Dealer
16/3/06
14,830
5,457
The first SH4130 movement daytona, 72H+ PR.
sfbatman787
920
799
Is this movement supposed to be better than DD4130 that clean, noob, and btf uses?
Tobel
5,504
3,741
Hopefully we're seeing more 116520's as well :)
sfbatman787
920
799
The finish of the movement looks horrible. And not to mention the black dial 😅
If its the same quality as the sh3135, then I'll stay thousands of miles away from this movement.
dogwood
2,526
5,768
Canada
Very interesting to see a new movement. Identification is easy compared to the DD4130. But it’ll be good to see a full part by part teardown and comparison with the Dandong 4130 (paging @CTime).
clayj
15
@CTime would be interesting to see the BTF, Clean and APSF panda dial side by side to check how this new entry compare with blue-hue Clean and snow-white BTF dial in the same shot.
At least APSF put the effort to differentiate the CORONET of the black-white dials as per gen lineup.
Cant speak about the movement aesthetic, im more into performance and reliability.
  • Wow
Reactions: CTime
daytona4130
363
74
is the bezel interchangeable with gen or it still use the old system like the 116520? (without steel ring between crystal and bezel)
Marius13
303
Albania
Regarding the movement I was looking at some of the photos of the watch listed on Intime, and I must say that the finishing of the movement looks much better than Dangdong / Clean / BT. And an additional detail which can be important for some, the APSF movement has a serial number engraived on the mainplate, like the gen movement.
Stas Roblev
37
Does anyone know if the APSF 116500 has an ARF bracelet, like Clean and BTF?
Anto.94
307
141
Florence
I order this for a friend of mine.
The watch is not bad, IMHO case, bracelet and SELs is better than Clean or BTF
Dial and bezel not the best
Movement has better finish and buttery winding than Clean
Reactions: dogwood
Tobel
5,504
3,741
It seems they can never get these pushers right :/
