Well ok, I understand now.
Power reserve can be a very tricky thing, especially when determining if a watch is autowinding well. For your watch we need to make the distinction between 2 issues:
1. Power reserve. Now simply putting the watch on the wrist is not going to charge it. The power reserve is determined by how much you move your wrist when the watch is worn. This also depends on how much power reserve the watch has when you start wearing it.
2. The watch running slow has nothing to do with the power reserve.
Now this is what you do:
1. From zero reserve (watch stopped running completely), wind it until the second hand starts to move. Then give it another 30 winds. Then wear the watch like you would normally. Note when the watch runs down to zero reserve again (stoppage of movement)
2. Note the timekeeping when the watch is worn at the end of each 24hr period and make a note.
The good news is that a proper movement overhaul and regulation will likely take care of both issues at one go. Movements often arrive dry and dirty from the factory and this can affect both the timekeeping and power reserve.
