AP RO Offshore thinning case
Nono92
2,017
813
Hi, what is the final thickness of an AP ROO with ceramic bezel after thinning (starting at 16.0 mm) ? Thanks.
AMF
Trusted Watch Dealer
Trusted Dealer
27/5/20
145
465
After modifying the rep, how thick is it ?
It can varying result .Some models from JF are thicker some are less. Depending on the individual model it can vary. Gen like thickness can be achieve if remove deco plate or exchange rotor .With keeping rotor and deco plate need to check individually as not all are the same from what have handled recently.
Nono92
2,017
813
OK. Then the priority is to rather change the movement than reduce the case by 0.5 mm... The problem seems to source the DD module 293. How can we get a new one ?
