Comparison | 8N-24 | 9015 | Compatibility | |||||
Movement diameter | 11 1/2" |
| Match | |||||
Movement height | 5.55mm | 3.9mm | 9015 slimmer | |||||
Winding stem distance from dial | 2.00mm | 1.53mm | 9015 would need spacer / dial dots | |||||
Hand spigots | (s)0.17; (m)1.00; (h)15.20 |
| Match | |||||
Dial feet | 14deg & 40deg from center | 17deg & 21deg from horizontal | Mismatch - chop feet & add dial dots |
For sure dial dots have to be used. And then a spacer needs to be made (3d printed probably)Hi, I'm interested in this too (for an IWC big pilot that the rep factories for some reason used the slower beat movement in).
I was looking into possibility of swapping 8N-24 for Miyota 9015 which is a hi-beat.
For these movements, my comparison indicates:
Comparison 8N-24 9015 Compatibility Movement diameter 11 1/2"
11 1/2" Match Movement height 5.55mm 3.9mm 9015 slimmer Winding stem distance from dial 2.00mm 1.53mm 9015 would need spacer / dial dots Hand spigots (s)0.17; (m)1.00; (h)15.20
(s)0.17; (m)1.00; (h)15.20 Match Dial feet 14deg & 40deg from center 17deg & 21deg from horizontal Mismatch - chop feet & add dial dots
So the hand spigots match but the movement thickness of the 9015 is thinner, and it looks to me like the dial feet are in different places. I have never attempted this kind of mod but figure you could remove the dial feet and then fix the movement with dial dots.
This may result in a higher quality movement solution, but not sure how feasible this is.
Reaps: did you make any progress for your beat rate problem?
Will look into the suggestion of the DG4813 but would love to hear from anyone knowledgeable on this to understand how doable a 9015 movement swap would be?
Hi, thanks for the response on this - sounds encouraging.I just finished putting a 9015 in my black fxd. Dial spacer was not needed, the movement holder actually acts like a spacer once the movement is screwed into it. I had to clip and file the legs on the dial, and affix to the movement spacer using dial dots... but everything went back together perfectly.
So do you have a 1mm air gap between dial and movement? or is this filled by the dial dots? Also, would this create issues with installing hands in the pinions?
I was hoping the dial dots would create about 1mm gap to fill out the space required to align the crown.
I don't have a 3D printer but know one or two people that do.
Here's the movement holder in the watch I was planning the operation on. Does it look like it could work?
I ordered a 9015 movement, but now need to source the watch!Did you wind up ordering the 9015 for your Big Pilot? I'm considering the same for mine, but I'll save myself the hassle if you discovered it wouldn't work.![]()
If I make it happen, I'll report back.
