So this will now be my third 6538 build after a mix up where raffles sent a 6538 case rather then the 5513, I can’t complain as they made it right and sent me the correct one. But it left me with this case and I thought, why the hell not. So I start by removing the bezel and stock plexi
Inspired by this thread I purchased another case from Ali with a nicer bezel and got to work
forum.replica-watch.info
As you can see it has teeth, and we don’t want that, problem time as I have no sanding tools, so hit by sudden inspiration I went with a very cheap approach of utilising the stone floor outside. Perfect!
Seems to fit well and I add a new T19 plexi
Now I go rummaging through my spare parts and stumble across this TC build I bought around 5 years ago, love the insert so yep il take that thanks very much.
Next up I want to age the bezel, under the grill it goes, 180 degrees for about half hour
Now we’re cooking!
I already reached out to a very nice member of this community who does some outstanding engraving work. I won’t add the name here as I don’t want them to be flooded with requests for help, however those who have been here a while will recognise the work and I will give the credit here if he wants to claim it, probably wise to see how this build turns out first though!
Looking good! At this point I realise I still have this leftover TC watch, the case and bezel actually look pretty good, so obviously I take it to pieces, age the bezel and decide to do a 2nd build alongside this one
Now I start to look at replacing the tube to fit the spare raffles crown, the TC tube is slightly too thin, as it’ll get messed up while I remove it I decide to jam a round tip diamond file in there instead and open it up a little, to my surprise the raffles crown now fits and the thread is a perfect fit! Awesome, that’s a bit less work to do!
Now have the two cases it time to start work on the two dials iv chosen. This thread is awesome and gives some great techniques
I’m starting off with some watered down citadel varnish, very thin coat and leave to dry, I’m not going mad here I just want a slightly glossy finish with some small imperfections
That’s where I’m up to for now. If anyone shows an interest then il continue this thread. If not, then balls to it
Beginning my 6538 Build…
Hi all. The journey has begun. I’ll be using this thread to document my 6538 build. It’s been several years since I last built a replica, so it’s fun to be getting back into this. So far I’ve been working on a Raffles’ case, and I must say for $50 shipped it’s quite a bargain. Sure, the...
Now we’re cooking!
How to age your Vintage Rolex (Bonesey style)
How to Bonesey your watch! Part I - The Basics Foreword: - 06/01/2019 Due to post size limitations the original guide was unable to show the pictures. Which is a shame of course. Please download the PDF Version to see the full guide. https://goo.gl/EmrP9r Or you can go to the Imgur post...
