Aftermarket Bezel insert for Rolex Submariner Hulk 116610LV
Xiiaodiit
314
105
Singapore
Hi guys, what do you think of this aftermarket insert for the hulk ?
Abduljay
753
189
Wow Looks amazing! Where did you buy it? And which base do you have? Noob?
Xiiaodiit
314
105
Singapore
I have yet to buy the insert, the pictures are review from other buyers. The insert is a custom made by a China seller. I’m gathering feedback to weather is this a good insert before purchasing and will share the info after I purchased.
Abduljay
753
189
Alright. Will wait for your review.
I am afraid to order inserts, because they might not fit my noob.
Abduljay
753
189
Any idea would they fit a 2836 VRF?
It is hit or miss most likely. Because the bezels are not 100% same size always.
Im planning to order one from sprongebob soon, will let you know how it fits.
Alternative is to ship your bezel insert to spongebod and he will do the paintjob. Then you are 100% sure it will fit.
Xiiaodiit
314
105
Singapore
Oh,i have a spongebob bezel for a noob v7 black 116610LN. Its fits perfectly. Im looking for other options besides spongebob and molotow mod.
Abduljay
753
189
Yes Noob 7 was great. I had it before. But now i have V8, heard there are problems with other bezel inserts...
But Ill let you know if I see anything interesting!
Smpfan
996
303
What base watch is this? I‘m asking because the crystal protudes really much.
Greets Andi
Dufan
211
45
Is it easy to disassemble and then reassemble the bezel Arf whitout risking to break it or break the glass?
Smpfan
996
303
You need a bezel removal tool for that. I strongly recommend this. If you try to pry off the bezel with a knife you will risk ceramic inlay damage.
Greets Andi
Xiiaodiit
314
105
Singapore
Greets Andi
It’s a VRF hulk with a ARF crystal. I bought this piece from m2m. It was on a prof blackhole
crystal previously. But there is damaged on the cyclops when I bought it so I swapped it out.
Before crystal swap (ignore the ugly molotow paint :/ )
Xiiaodiit
314
105
Singapore
Greets Andi
The base is VRF. I bought this piece from m2m,than it came with a prof blackhole xtal but the seller didn’t state there are many scratches on the cyclops. Ignore the ugly paint job
Prof Blackhole crystal
It’s now mounted on a ARF crystal
Is it very obvious that the crystal protrudes high to the naked eye?
Smpfan
996
303
From the side view it looks pretty good. So I think the ARF crystal chamfer maybe is a little bigger and the new insert ist sitting so slightly deeper.
I know this scratched cyclops problem. The reason is the AR coating on the outside of the cyclops. Prof‘s and DSXtal‘s crystals are using this technique.
Simply remove the coating. You won’t loose the black hole effect as there is coating applied from the underside of the cyclops, too.
Greets Andi
Reactions: KJ2020
Xiiaodiit
314
105
Singapore
Greets Andi
I see. Can I use cape cod to remove the AR coating ?
Reactions: KJ2020
