Advice - a thin, 44"
jaaackle
62
UK/Japan
Hopeful - can a kind soul point me to a specific thin panerai replica? I'd be very grateful - I'm keen on the panerai size, but not the width - are the only options one of the 3 days?
Sincere thanks in advance,
mysterio
9,793
867
I suppose you meant thickness not the width. There are no "thin" 44mm PAMs. The thinnest is 15mm for the standard Luminor cased models (the PAMs using the P.5000 are thinner in gen by 1mm but I think the reps use the same case so the thickness of that rep is the same). The 45mm Radiomirs are thinner at 13mm even though they are a little larger. And these are for manual winds, automatic movement powered models are at least 1mm thicker.
