Hi RWI
I am trying to replace the rotor of my A7750. I bought the following parts from cousinsuk:
VAL77501491 - Valjoux 7750 1491 Oscillating Weight Bolt
P38796 - 7750 Key for Oscillating Weight Bolt
P19255 - Horotec Multi Functional Tool Hand Piece
See picture for the parts and tool (screw is not pictured): http://i.imgur.com/9Lzl6Vn.jpg
cost me around £120...
Now the issue is that I can't attach the ball bearing to the oscillating weight. I am following a tutorial on youtube: https://www.youtube.com/watch?v=z8-f0hyIqxE
He even has the same tool (!) and it goes so smoothly.
However, I can't attach the ball bearing using the bolt ... it simply wont hold - I am turning the tool clockwise around 45 percent, but when I remove the tool all parts fall apart again.
When I used a lot of force pressing down the tool, I even scratched the rotor surface a little
How is this supposed to work? I thought replacing the rotor would be a trivial task, however after dozens of tries I gave up. What am I doing wrong?
Thanks for any help, I'm really desperate.
Oscillating Weight Nickel Plated (Without Ball Bearing 1497) ( 1143 ), Valjoux 7750 (VAL77501143) |
Screw For Oscillating Weight ( 51143 ), Valjoux 7750 (VAL775051143) |
Ball Bearing ( 1497 ), Valjoux 7750 (VAL77501497) |
