A7750 how du set and all things for first timer ?
rahmboo
Hello!
i just bought i Hublot big bang chrono 44,5mm from a member here on the forum, its my first rep and i dont know anything how its works more than what a read on this section.
The Watch is still now so i need to start it again, so i wonder what direction or how i should wind it again?
I have read that you should not set that when the Watch is in some positions and some stuff but i dont realy understand all,is there any site i can se Pictures on or something?
The last owner of the Watch is not in that often so hard to get some support from him :hypnotized:
Watch is now at 18:45(i Think) and the chrono meters on 12 and 30.
hope you guys can help i first timer like me,very thankful for that.
Kind regards.
zero_deficit
1,682
Yes i have read that but dont understand how or where to set date on my big bang chrono Watch, and how do i know if its am or pm on it when the Watch was still when i got it? it says in the guide that it is bad to change date between some time so.
Thanks.
When the crown is pushed in, it is in winding position, wind clockwise
Pull it out gently and the first position it 'locks' in is the date setting position, wind clockwise to advance the date
Pull it out again once more and it'll be in the second position, this is the time setting position. Rotate clockwise or counter clockwise to set the time.
You'll know whether its AM or PM when you advance past 12. If the date changes when you go past 12, then obviously it is AM, it it doesn't then it's PM.
The button at the top starts and stop the chronograph (the big hand), after you've stopped the chronograph, the bottom button resets the chronograph
rahmboo
ok thanks mate that helps me alot.
But should i really use the reset button? i read in the guide that i should never resets the chronograph ?
zero_deficit
1,682
Just wonder doe,they dont recommend to manual wind the 7750.
How does you wind the Watch if you not do it on the Crown manual ?? :doh:
Give it a couple of gentle whirls to get it up and running and then wear it
