A7750 direct swap?
EM9
Watch Acquisition Disorder
1,371
1,496
28.3772° N, 81.5707° W
Hey fellas, is an a7750 on the older PAMs a direct swap after removing the chrono bits? Likewise anyone know if we can swap in a 7753 on an a7750? Looking to get started on a few projects but wanted to see if anyone has had success in the past. TIA
Rx4Time
Supporter, Panerai lover
11,956
10,611
Any 7750 whether it be ETA or clone should work in a non chronograph Panerai once the chronograph parts are removed. As far as the 7753 to 7750 swap, I believe you would need to source a new date wheel and you may also have issues with the dial positioning in the case since it's intended for a thicker movement.
Reactions: @(^_^)@ and EM9
Plaasbaas
IWC-hoarder and PAM-hunter
3,146
7,369
Also, from my personal experience, sometimes you get different pinion diameters for some of the hands, so best keep those wheels if the teeth are still intact.
