A6497 handwind.. ? or consider partial auto?
collector00
208
Hi,
understand that A6497 is handwind but when it was completely not moving, i gave it a shake n the internal spin, the 2nd hand moves......
my question is, If i were to place it inside a watch winder, will it continue to wind up?
OR... will it stop after 2 days or so which then requires manual winding?
kindly advise.
thanks!!!
junbug5150
4,209
23
Shaking it just moves the balance, which is why it moves. If you have the case opened and if you blow on it, it would do the same. Isn't auto since it's not necessarily winding the watch.
Raddave
Administrator
67,017
18,570
Check the beat error.....
collector00
208
hi buddy... mind educating me on the last statement "Isn't auto since it's not necessarily winding the watch."?
so.. it is pointless to put inside the watch winder?
Raddave
Administrator
67,017
18,570
beat error? what's that?
Basically its the amount of swing the balance wheel has in one direction compared to the other direction....if its too far off the watch wil not start on its own
junbug5150
4,209
23
It won't "charge" if put on a winder. The second hand moved only because the balance, through that shaking motion, moves. The second hand will stop as soon as the balance stops since it isn't charged (hand wound).
Raddave
Administrator
67,017
18,570
[MENTION=93965]junbug5150[/MENTION] :D
Raddave
Administrator
67,017
18,570
Yeah !
And apparently i misread your question too !
Listen to Junbug, hes correct !
BullishAndrew
90
North America
As stated, a hand wound watch lacks the rotor mechanism which captures movement and winds the mainspring. With a hand wind, You must hand wind in order to charge mainspring, a watch winder will never accomplish any more than the occasional tick that you witnessed.
Sent from the RWI mobile app
