A quick QF Lemans review
HelloBusby
Addicted To Peeling New Watch Stickers
413
253
QF Lemans Review
Overall, this was a great effort towards recreating the elusive Lemans Daytona. I’m not sure why many factories have not created this version, but what made me reluctant to try QF was the lack of the sunburst dial. Not anymore…
The QF LEMANS HAS THE SUNBURST DIAL.
Although, I feel like you have to ask for it. And depending on the dealer, you might get different responses. I have a very good relationship with mine, as I have purchased countless watches from them. So some of these problems I hear about don’t necessarily apply. Money talks, period.
This quick (no pun intended) review will primarily address the dial qualities and to a lesser extent the SEL fit (because it really depends on the piece that you get), rehaut, and overall case accuracy.
The Dial:
It has the SUNBURST. At that point I was sold.
Interestingly, it is very difficult to spot the sunburst in low light or indoor settings. I’m not sure if this is common in the gen or if it is a consequence of the black dial color, but I initially thought that it didn’t have it. What you can see, initially, is the way the light bends and warps, which would lead someone to think sunburst. But it is not readily apparent. When I first saw it, I used my iPhone flashlight to try to elicit the effect and tried putting in down light (indoors). All with little success IMO. Again, I have never seen the gen in person and probably never will, so I don’t know if this is how to real one works too.
But this story takes a drastic turn, when brought outside. The dial jumps to life and the effect is inescapable. It is like a symphony of light and every small detail on the dial surface shines. At this point, there is absolutely no denying the presence of the sunburst. Again, not sure if this is how the gen responds to lighting situations.
Overall, it is a beautifully crafted dial with the details seemingly there. The Daytona is not my main focus in comparison to other watches I focus on, but from looking at gen pictures, it seems very close. I had the Clean 12 Daytona, and there is nothing that sticks out that says “inferior” to it. The markers and hands seem very good and nothing about them sticks out to lead me to believe instantly that it is a replica. The dial printing is sharp and substantial. The red on the Daytona is a rich but not dark red. The subdials look silver in indoor light but sparkle when brought outdoors. Text and dial spacing were unremarkable, no problems noted. 10/10
SEL:
The bracelet seems substantial. My dealer does a very good job of picking good cases and bracelets for me, but being that the “sunburst” version might be a novelty, I wasn’t very picky. This bracelet in comparison with my Clean, was not as even with regard to symmetry but QF was more solid in regard to fit. There was no lateral movement whatsoever. I am very impressed when replicas accomplish this because even genuines may have one that slightly, ever so SLIGHTLY, moves, like so minuscule that you might think it didn’t. So an A in my book to QF, at least for the fit. 9/10
Rehaut:
I’ve never seen the Gen, but it looks pretty good to me. I know how submariner rehaut looks, this one looks pretty good IMO. 8/10
The Case:
The case shape and overall presentation is impressive. pushers seem on point and the crown seems well detailed. Decorative elements of the movements seem somewhat polished and generally seem impressive. I’m not too picky about that kind of things. The glass is a good height, clarity was unremarkable, and thickness was spot on. So it was 9/10 in my books.
Other:
What always makes me reluctant of the gold versions is the inaccurate tone. Unless you just wear this watch outside, in low light settings it will be an easy tell for those informed. Maybe even outside for the well informed. If factories could just get this done from the get go, it would be great, but other than that you have great alternatives in the US (Flandad and Majorwilliams) who do an excellent job! In some ways, they probably will do a better job than if a factory does it. It will just set you back about $300. For me, it’s more a matter of time. When I get my watch, I want to go ahead and start wearing. Sending it off is not really what I want to do. Which is what you need to do (at least for Flandad) who require stickers to be present prior to plating. And finally, with regard to weight, it clocked in at 142g with full bracelet. Not a deal buster for me but would love to see it heavier.
In summary, I would rate this rendition of the Lemans from Q Factory a 9/10. It’s a good option for those itching to get a Lemans. I don’t think you’ll regret it (at least for the sunburst model).
Hope this helps anyone looking to purchase this version of the Lemans.
Viva RWI! Thank your Mods!!
Rolex_Simon
3/2/24
11
Awesome review. With your experience, how does the movement / accuracy / overall experience compare to other Daytonas from Clean? i.e. would you advise others to just go for Q or wait until Clean comes up with one that may/will be better?
Reactions: HelloBusby
Maximillian
3,170
6,183
Böhmerwald
Thank you for the detailed review, well written!
I have a question: Since I have no idea about the white balance settings of your cam and the RGB of my old Macbook, what do you think about the golden colour of the rotor? Is it true to the photos, which are a bit darker like bronze, or it looks lighter than what I see in the photos?
HelloBusby
413
253
Clean doesn’t have a DD. I don’t want to insult any big fans of Clean here, but the first thing my friend said when he saw it was “wow it’s smooth.” And I agree.
I think it’s the same movement Clean uses. But for whatever reason, it sweeps better than my 12 Daytona.
HelloBusby
413
253
It’s not dark, but it’s not Rolex gold light. That can only be accomplished with plating by @Flandadcash or @majwilliams0308. Which is what I would recommend, at least for the case and bracelet if you really want to geek out on this watch. And it’s what I plan on doing.
Maximillian
3,170
6,183
Böhmerwald
Thanks for the info.
To me, the real turn-off of any gold or white gold rep is always the weight, and tbh this is beyond even a tungsten weight-added rep could fix. A nice plating can fix the look, but still something missing.
25,183
Hi, great review
May I ask your opinion on the rotor and backplate finishing? Of course we can't expect gen levels from a rep but I'm just curious on the quality.
HelloBusby
413
253
Hi, great review
It is shinier than what I expected. I didn’t think they would put too much effort into it figuring it’s the only one on the market, but it’s impressive to me. I haven’t studied the gen or know which marks are suppose to be there, but from what I can see, the engravings on the rep might be deeper than the gen. The rep, understandably, has rougher machined marks, but it looks like they tried to smooth it out. More so than some of the closed back movements I’ve seen. I think the plate lends to being able to be worked on for someone who knows how to do it.
Hope that helps. I’m not very informed with regard to movement aesthetics, so I’m not very picky.
Here are more pics of the back with some interactions with sunlight.
SS72
3,101
11,392
Australia
Fantastic. Thanks for the pics and observations.
I really liked this Ref before and even more so now.
Oh, and if I can route my future purchases through you, that would be awesome. (y)
guru
11,781
1,609
Good review, thanks.
Looks like the dial is very good. I looked at all 126529 YuTube videos, 90% show a black dial, and the video was always done in the inside. Just 2 videos show the sunburst, these were taken in the outside. Looks like QF nailed it. If the bracelet has a good quality then this is the way to go. Looks like the crystal has single AR.
How thick is the watch? 12.2 mm?
Sirmoog
144
86
I have it. I am no rep expert, but I love it! Keeps perfect time. I don’t use chrono feature much, so 12 hr vs 24 timer doesn’t matter to me. Great size and weight, and just a great story behind this Rolex and Le Mans. The little blocks at the end of the hash markers in the subdials is killer, as is the chrome rim around the bezel. This will be my only Daytona, no need for another.
guru
11,781
1,609
Yes, it is a beautiful dial
HelloBusby
413
253
11.9mm
Reactions: raremedium and guru
guru
11,781
1,609
perfect, same as my CF 126500 .
looks like I need to put the order in instead of waiting for the CF release which may come or not. I still believe if anything will be released from clean it will not be this watch. Maybe little LeMans on Oyster in the near future. Want to enjoy the watch now and not when I‘m dead.
