A question of whether to Sinn or not
KraftMac
Bluebox Champ
5/4/14
133
59
Central TX
Listed $168 @ puretime, but also was posted in 2011.
Sinn aren't super common, so not sure if either of them would have in stock at the moment.
Message the TD and ask before placing an order.
TT is not a TD here on RWI. Take that into consideration.
jaaackle
62
UK/Japan
But puretime no longer have those in stock. TT do. I wonder (in all actuality) whether there would be any specific difference with the watch itself, i.e. truetime vs. trusty time? Any thoughts?
Stealthy
MULTI ACCOUNT
9/4/13
468
I think they've stopped making this anymore....I was lucky to own Sinn U2 GMT from PT with real ETA movement, it was around 500ish USD IIRC and it's still running strong till now
jaaackle
62
UK/Japan
excellent. happy to hear. It is available from Andrew. I used to own a genuine EMZ2. Can't justify the expense on a gen, but....
Reactions: Rambo73
marco130
642
1,103
marco130, is the movement 28000? Running well, reliable, etc? How long have you had it? Many thanks for you reply.
7750, 28800. Good amplitude, pretty accurate, stable. Only have had it for a couple of months but so far so good. Winds nicely
jaaackle
62
UK/Japan
Many thanks. I once considered one of these as a gen, but was put off by many claiming they were simply too big. Do you have any take on this? Is the watch (from memory) 45x17? What are your impressions?
marco130
642
1,103
It’s big and it’s thick but sometimes that’s what I feel like wearing. The pushers on the left hand side seems strange sometimes when I’m putting it on. I’m used to them usually being on the other side
eta2893
40
21
marco130 how many millimeters thick? Do the pushers dig into your arm when you bend your wrist backwards? Would you wear it with a long sleeve shirt?
marco130
642
1,103
Roughly 19mm thick, plus or minus 1
Pushers don’t dig in at all
I have worn it with a long sleeve shirt. Usually have to pull the sleeve over the watch unless I want to have it readily visible
Reactions: eta2893
Rambo73
252
Cant Wait to become a Sinner myself with a EZM1.1 Strapped on my wrist with Nato
