9401 build with original 2776 movement case info request
mojoatomic
I have a 2776 , Tudor rotor & dial lying around and I'm wanting to fit these to a reasonably accurate case. What's the advice from those who have done similar? Is there a 9401 style case that will fit the 2776?
RDRoss
4,784
7,639
Phong or MQ would be the bet as a starting point.
jackflash
1,449
2,946
Go with Phong. The 9401 case set I bought from MQ was disappointing for the price. I ended up replacing the bezel assembly (WSO), crown and tube (Athaya) and crystal (SK). The mid-case needed reshaping and the lugs drilling. Even the rehaut was wokky. MQ is also a pain to deal with.
Here’s the result. Bezel insert from Phong. Viet dial off ebay. Hands and dial re-lumed.
Solution6
Watchmaker
Vendor (Watch Repair)
555
619
London, UK
Another option is to use one of Milk's 5513 cases, much cheaper than a Vietnam and almost gen spec. The only thing as with all his cases is that they're blank, so you won't have the lug engravings, but this does't matter if you use it with a metal bracelet ;)
Give me a shout if you need advice on this and here is Milk's user name.
milk051506
Solution6
Watchmaker
555
619
London, UK
Is that a Tudor buckle good sir?
Also, how are you getting on with the Athaya crowns lately? Every second one I picked up had a faulty clutch and the quality of the stamp is a bit silly - the dots are almost non existent. The worst part is that Adrian ignores all emails regarding these issues. Think I'll be looking elsewhere for any future builds.
nissin
8/4/14
11
Anyone know how to contact vintagewatchesmq? His yahoo email on the website is bouncing back.
