7th order from Andiot a VSF Rolex Starbucks for $280 usd Best Deal Ever!!
Koalalakabear
58
Ordered the best deal ever!
Submariner 41mm VSF 126610LV The Youth Version Green Ceramic 904L Steel A2824
$280.00
Its a VSF case, VSF quality, and only difference is the movement.
  • Size : 41mm x 12.6mm
  • Movement : Nickel plated A2824-2 automatic movement, 25J, 28800 vph
  • Functions : Hours, minutes, seconds and date display
  • Case : 1:1 high quality 904L stainless steel
  • Crystal : Rounded edge scratch-proof sapphire crystal with anti-reflection coated 2.5x cyclops (Swiss standard, double-sided, same as genuine)
  • Dial : Superlumed dial and hands in correct blue color
  • Bezel : Uni-directional rotating green ceramic bezel, very close to genuine green color
  • Strap : 904L stainless steel bracelet with perfect SEL, clasp and divers extension and smooth screws
  • Clasp : Deployant clasp
Koalalakabear
58
$280.00
Got Qc
25/04/2025Processing
michaeldingyi
20
Looks good! So the date window is fine, right? At least from what I can see, it looks great. But others have noted that there's a greater chance for the date wheel to be misaligned due to the smaller movement.
Koalalakabear
58
Never heard of that. Thanks for the info.
Reactions: garyg
garyg
15/5/25
14
Delivered and the watch looks great! Thank you Elliot and the Andiot :) team!
Im new in all of this.Im new to forums and even to reps. I really wish to ask you 2 question before I make my 1st order.I would really appreciate if you answer me I think you have experiance .But If you dont have time to answer me, I thank you as well sir.Im about to order my first 2 reps, the Daytona Clean 126519LN & the sky dweller v1 ZF. Do you think in your opinion that Im aiming for the best factories for each model?
Something else.In your opinion ,2 watches of the same model and same factory, one priced at 1000 the other priced 650.can they be of the same quality level.
Thank you very much sir ,and sorry for my English.Im from Malta.We mainly talk Maltese.
Koalalakabear
58
This chart will help you out.
Reactions: garyg
