I just received a 5th Gen PO and the first mod I'd like to make is to replace the tube and crown. I've seen on posts where people have removed the tube and glued in the replacement. However, since it appears that the genuine tube is threaded, I was wondering if anyone had ever tried to tap the hold on the case?
Am I over thinking this and just using marine epoxy is the easiest?
That's for your input!
