yeah agree, I didn't mean to cause offence with my last post, just that that level of nit-picking is taking it too far ott, nobody will notice these things, anyway, if you are going to go cheap and get a relume or all out and get a gen dial...(either is a must) then the marker angles will be sorted then fairly rapidly
I'd agree with matt, the rep crystal is not perfect out of the box but it does look similar to the older bluer AR'd gen PO that was out from around 2005ish-2009ish, it just lacks the strength of gen AR transparency (If that makes sense) The newer PO's 2009 onward have less blue and more clear AR so it depends on what you want. I'd get the rep crystal AR'd personally as it would then be very close to gen, the gen crystal is very expensive.
So we have stem, crown, tube...a must. Gen dial/hands, then crystal/bezel(your one is fairl y good on it's own, I'd leave that as is, the gen is £200 arrrgh!) and He valve is just cosmetic. Not really worth bothering with that.
Really depends on how far you want to go, you can have a gorgeous watch with gen dial/hands/crown/tube and AR'd crystal for £400ish or you can go all out and double that price for the other very minor additional touches. Not worth it imo unless you absolutely love the watch, and if you do then you'd be looking for 2nd user gen.
