Latest comparisons of CG
I have arranged and enlarged some CG pics for a comparison
Thickness at CG PIN side
- PT is just a bit thinner and Cartel is a bit thicker, almost no noticeable difference even with enlargement. Orange lines are placed at the same distance of GEN in three pics.
Lever PIN diameter
- There are seemingly some differences but it is a lighting effect. I think all three Lever PIN diameters are the same. See green lines
Lever PIN position
- PT has the PIN placed clearly inwards. Due to this reason maybe the CG seems thinner around the PIN
- Cartel version has the Lever PIN placed a illtle lower. See green lines
Roller Support
- PT roller support is a little thinner
- Cartel roller support is a little thicker
Engravings fonts and placements
- There are some differences between batches. I have seen some differences in QC pics and Wristshots
- Cartel and PT have bad placement of engravings in general
- Fonts are inaccurate. Mainly "R" is very noticeable.
- Following my experience with all pics observed, Pt has better fonts and worse placement overall.
ALE
