288k maker: 253i and 212i
MMs
1,924
212i: http://www.1-pc8838.com/0pn212i01-212i-1950-flyback-chrono-ssru-28800-p-9601.html
Size: 45mm x 19mm
Movement: Asian 7750 automatic chronograph movement at 28800vph
Functions: hours, minutes, sub-seconds and working chronograph
Case: solid 316L stainless steel case with running individual IXXX/900 serial numbers
Crystal: super dome mineral crystal with colorless anti-refelction coating inside (same AR as genuine)
Dial: black dial
Bezel: polished fixed bezel
Strap: sport deployant rubber strap
Clasp: deployant buckle
Water resistance: >50 Meters
Other: polished lug screw head and tail, flush crown guard lever pin, free silicon watch protector
Remark: 1:1 replicated from a genuine watch sample, all parts are interchangeable with genuine, made by HBB V1 maker who also makes the PAM288K and PAM177L Ultimate Edition
__________________________________________________________________________________________________
253i: http://www.1-pc8838.com/0pn253i01-253i-regetta-flyback-chrono-ssru-2880-p-9600.html
Size: 45mm x 19mm
Case: solid 316L stainless steel case with running individual IXXX/500 serial numbers, Classic Yachts Challenge 2006 engraved on caseback
Dial: black dial
polaris
398
Looks like after many expensive HBBs the maker is going after the cheaper end of the market.
$248 is pretty good for what it is. Would prefer a sapphire crystal myself tho.
polaris
398
hmm
There is a 253/212 crystal project here and here
That could be interesting. Some would say the movement's lack of regulator, novodiac kif? shock system are instant flaws. I don't care much about the back. A new crystal with single AR, even if $100, would make this a nice rep. I don't know much about this model tho.
QinetiQ
4,585
It bottles my mind why they used mineral crystal instead of sapphire. Is that how the gen is?
polaris
398
Gen is sapphire
Could be the shape/curvature wasn't worth their while.
polaris
398
Does it has correct CG chape?
plaifender said:
- Blue second hand is correct as per gen
- Crownguard and pin for lever correct as per gen
- Lume is better in this version
- Caseback I series number engraved
- Rotor engravings look correct
Seems a lot better than the old one. Just the mineral glass crystal, movement all I know of.
chromed.
2,460
i really like e 212i, been waiting for a better rep&now its here..
other then e mvmt flaws, i think e dial, cg, crown, markers&all r gd, how bout u guys.?
D
d4m.test
Guest
Please can someone explain what is wrong with the movement? I am seriously considering buying one and I would like to be sure it will last!
Thank you!
brahmabull
On the hunt for PAM163,212,213,288,286,253,228,297
1,251
3,434
Tar on toe
just reviewed the 253 with the actual pictures from the Panerai special editions catalogue. The biggest thing that stands out is that the movement is very different to the picture. The font on the back casing for 'OFFICINE PANERAI 30 jewles is a different shade of blue. Not a big deal as this is the back of the watch.
The front is pretty exacting. Slight difference in font for the tachymeter. Everythign looks pretty good.
D
d4m.test
Guest
What exactly is a working regulator? And how much of a problem is it to not have one? Thanks!
MMs
1,924
fixed.
I ran out of bandwidth, so from now on my bandwidth is unlimited.
hooligan
8,332
Yes, these domed mineral crystals are the ones that tend to crack/break.
The "regulator" is a small needle indicator for adjusting the speed of the movement. It's not a *huge* flaw, since anyone who knows what they're looking at will know it's a fake the minute you turn the watch over.
The best 212/253 reps made, by far.
D
d4m.test
Guest
hooligan, does this includes the newer versions made by the 288K factory? I read in another forum where Josh explained that the mineral crystal in this version are much thicker than the previous exploding ones. What's your take on this claim?
If that guy knows what he is looking for, then I believe it will not make any difference even if the regulator is (modded) to be there. Most obvious being the lack of cotes de geneve?
