- 23/9/22
- 46
- 58
- 18
Amazing quality Oyster Flex Straps in size 20mm & in White or Black.
I have most sizes available (E-D to E-G)
Also, available are the very convenient Glide-lock clasps, I know the Daytona models have the micro-adjustment (3 pins instead) but imho the glide-lock is much more convenient & easy to adjust on the fly.
The clasps are available in Silver, Yellow Gold & Rose Gold.
These straps fit all 20mm models, Daytona, GMT Master II, Yachtmaster & Maxi Sub 116610.
In photo I actually pair these on the new 21mm lug width Sub, just to give an idea.
But if you do have a new sub (126610) you'll need the 21mm version or be able to live with a 0.5mm gap on each side.
In any case I took some pics to provide an idea.
But all 20mm lug width models your good!
Please see the table below, I have gone through all the sizes of straps to measure the strap size you need.
Tip on when selecting your size, you ideally want your size to be in the range so you have room to adjust the clasp when you wrist expands or goes thinner according to temperatures.
For example a 7 1/4" wrist, the appropriate selection is: 5. E-F & E-F → 7" to 7 3/4"
That way there is a little wiggle room.
Last point when sizing there is a one-size-apart rule eg. E-D & E-E is ok but E-D & E-F watch will be a bit lob sided.
To make it simple please check my size guide where you can look up your wrist size & your suitable size.
International via FedEx Priority.
Ok, Last bit, here are the individual sizes.
E-D: 45mm
E-E: 50mm
E-F: 57mm
E-G: 70mm
- 1. E-D & E-D → 6" to 6 1/2"
- 2. E-D & E-E → 6 1/4" to 6 3/4"
- 3. E-E & E-E → 6 1/2" to 7"
- 4. E-E & E-F → 6 3/4" to 7 1/4”
- 5. E-F & E-F → 7" to 7 3/4"
- 6. E-F & E-G → 7 1/2" to 8 1/4”
- 7. E-G & E-G → 8" to 8 3/4"
E-D: 45mm
E-E: 50mm
E-F: 57mm
E-G: 70mm
