111M N-movement into H-Case?
HB212
1,011
Heya Pam gurus. I've got an H-Factory 111M and I was hoping to upgrade to a N-Factory hi beat movement. Will the H-fac dial/hands fit onto that movement and will everything fit into the H-Fac case?
I guess what i'm getting at is, how easy will it be to fit the hi beat N-Fac movement into my H-fac watch?
alvinado
Watch Nerd
6,015
708
Asia
dial will fit, movement will fit.
the hands might fit depending on luck. The second hands for H factory is too loose for the N factory movement. You may need to crimp it a little.
Spboudart
4,398
I also beleive that the dial back plate is thinner on Noob mvt.
To be verified.
But when I put a Noob dial/hands/mvt assembly in an H fact 177 case, I had to use 4 mvt tabs (2 instead of 1 a each holding screw) to hold it together. No big deal though.
HB212
1,011
Ok, so if I'm able to snag an N-Fac movement, dial and hands together, they should just swap right in. Sweet!
