• The finalists in the Mod OTY have been chosen, please go vote in the finals: MOD OTY Link
  • It's our birthday and YOU get the gifts! Eight giveaways including six watches that you can enter for free! RWI Birthday Free Gifts Link
2836 : Parts needed for replacing of Keyless Works/Winding Stem
jpohl402
5,327
17
If a 2836 movement has a Poor/not high quality Keyless Works/parts, and also you don't want your Winding Stem chewed up,
Which parts would you/should you replace? I have not a clue! Would you also replace the Winding Stem with a more durable one? Or just address the Keyless Works parts, using GenETA, and completely leave the Winding Stem alone?
PS. This is a brand new, never been used mvmt. I am simply using the notion that other similar mvmts for this watch have had issues here, and want to upgrade early/right away ;)
Thanks in advance!!
hub6152
1,606
Hang on until tomorrow and I'll give you the ETA part numbers. I'm about to go to sleep!!
Sent from hell
chris3007
9,407
118
Here is the complete keyless.
If start to change, I wou change all parts, including the stem
The numbers at the pic are the ETA part numbers. The stem is 2836.401, for example
Sent from my iPhone 6
hub6152
1,606
The specific parts worth changing as well as the stem are:
407
410
425
435
443/1
445/2
450
Sent from hell
hub6152
1,606
Just note that all ETA movements use the same numbering for the same parts. The movement number must be placed in front of the part number when ordering like Chris shows.
Sent from hell
jpohl402
5,327
17
407
410
425
435
443/1
445/2
450
Sent from hell
Just wanted to thank you, my friend! ;)
And thanks for the diagram Chris!! Appreciate it!
KBH
7,168
As far as keyless, I would leave well enough alone until you have a problem. They aren't nearly as bad as you're making them out to be.
If anything, I'd agree about the winding gears but I think if you're going to buy all the gears separately you can probably buy the whole bolt on module just as cheap, or close to it.
Tickleshoes
932
302
45th Parallel
True. I believe OFrei sells the whole auto bridge but their prices tend to be double what Startime charges - it's good to have (or know someone with) an account ;) those 2 gears are $18 + shipping vs $30+ at OFrei.
