Polishing Lathe
mclarendude
𝙟𝙚𝙩𝙨𝙥𝙚𝙚𝙙
26,708
29,458
ATL
Hey gang:
Been wanting to venture into refinishing my own bracelets/cases because might as well.
Any recommendations for an affordable beginners lathe and compounds?
Thanks.
bc1221
Put Some Respect On My Name
30/4/14
4,079
454
Harbor freight has a bench grinder with a polishing wheel and some cheap composed for less than $50 last time I was there. I just don’t have anywhere to put it but it’s fairly small. Prob about a foot wide.
Hell, here’s one for $30 bucks and comes with a cotton polishing wheel.
https://www.harborfreight.com/3-inch-mini-tool-grinder-polisher-94071.html
You just need to buy a finer polishing wheel and some good compounds.
I just use my polishing drill bit, clamp it down to a bench and use it that way when polishing a case. Then I use my dremel for smaller work.
You can get great results from just using very fine sandpaper as well. I use something called finish sand paper. The finest one feels like paper but it damn sure polishes it. It’s just very time consuming but for work like polishing the chamfered edges, it comes in handy. I just wrap it around flat sanding pad and keep it at a 45 degree angle.
Perpetual
2,370
3,600
Hey gang:
Thanks.
I would shop around for a bench grinder that had a speed setting because "specifically for brushing " requires a slower speed, rather then polishing that requires high speed. Just my 2€
beau7816
6,933
1,685
UK Devon
I used to use a Dremel which is very good and have since purchased a Jooltool which is excellent. I use a test case and scratch it up to practice polishing skills. Now can comfortably say my polishing and brushing skills match new watches.
Sent from my SM-N950F using Tapatalk
p0pperini
patr0n h0arder
8,984
30,123
I got one from Amazon - I specifically searched for one that had a variable speed function, because it seemed pretty clear that controlling the speed would be useful.
It's small but has enough power to polish and buff watch surfaces just fine. I wouldn't expect it to handle anything more demanding though.
beau7816
6,933
1,685
UK Devon
The zJooltool has removed so e quite deep scratches. However you also risk altering the dimensions of the case when using abrasive pads before polishing. There are plenty of vids on YouTube, just type in Jooltool.
p0pperini
patr0n h0arder
8,984
30,123
The Jooltool looks a nice bit of kit - being by 3M I guess you’d expect it. But damn it’s expensive!
