Does anyone know of a rep in the following configuration from a quality factory? Datejust, 36mm, S.S., 2824 or 2836, oyster, stick markers?
Come on Roadster search for it ! You can find a lot of info about the DJ on this forum..
Verzonden vanaf mijn iPhone met RWI
https://puretimewatch.io/datejust-36...let-a2824.html
There's no such thing as a "quality factory"
Noob has done great watches as well as crap ones, same applies to ARF, JF etc
Thanks for nothing.
I've searched until the cows came home without results. Likewise been up and down this forum without results I'm thinking such a rep maybe doesn't exist. One of the key requirements being a "quality factory". This post is sort of a last resort. So if all you're going to do is lecture me to feel good about yourself then go stuff it.
DJF has the 36mm DJ with an 2824 also available with Stick markers and oyster Bracelet search on websites by Any TD. Also check Posts ARF VS DJF and make your choice! Good luck...
