Wow Looks amazing! Where did you buy it? And which base do you have? Noob?
I have yet to buy the insert, the pictures are review from other buyers. The insert is a custom made by a China seller. I’m gathering feedback to weather is this a good insert before purchasing and will share the info after I purchased.
Alright. Will wait for your review.
I am afraid to order inserts, because they might not fit my noob.
Any idea would they fit a 2836 VRF?
It is hit or miss most likely. Because the bezels are not 100% same size always.
Im planning to order one from sprongebob soon, will let you know how it fits.
Alternative is to ship your bezel insert to spongebod and he will do the paintjob. Then you are 100% sure it will fit.
Oh,i have a spongebob bezel for a noob v7 black 116610LN. Its fits perfectly. Im looking for other options besides spongebob and molotow mod.
Love the Boss man, he rocks!
What base watch is this? I‘m asking because the crystal protudes really much.
Greets Andi
Greets Andi
From the side view it looks pretty good. So I think the ARF crystal chamfer maybe is a little bigger and the new insert ist sitting so slightly deeper.
I know this scratched cyclops problem. The reason is the AR coating on the outside of the cyclops. Prof‘s and DSXtal‘s crystals are using this technique.
Simply remove the coating. You won’t loose the black hole effect as there is coating applied from the underside of the cyclops, too.
Greets Andi
