hybrid ARF & VRF3135 116610LV - what are the best parts from each?
ark2506
289
If one had both the ARF and VRF 3135 hulk and wanted to build a better hybrid with the best of both worlds, what would be the best part from each?
Dial
Bezel
Crystal
Bracelet
Case
capice
2,715
558
Dozen of pages written about it...try a search....
Smpfan
996
303
Short answer if you’re going with Rolex clone movement:
VRF: all parts but crystal. Go gen or prof.
ARF: nothing
ARF bracellet is better but will not fit properly into VRF case I guess. Lugholes don’t line up with springbars.
Greets Andi
Reactions: phdsjain
32,783
59,017
Problem with bracelet fit is the width. The ARF and Noob are right at 20mm, the VRF is llike 19.92mm Always possible this is a one off, or a batch issue as there is only one report of this and the VRF TT bracelet fits a Noob GMT.
Smpfan
996
303
I can confirm that the lug width of the VRF Max also is narrower than 20.00mm.
Greets Andi
